[mpich-discuss] some help in the simplest problem mpich2
hatem Elshazly strongwave83 at hotmail.com
Sun Feb 13 12:05:26 CST 2011
ok guys, i sorted it out
u must stage the executable in a mounted file on the whole network
as in NFS or stage it in the bin directory of your home in each node in the cluster
thanks
regards,
hatem
Subject: some help in the simplest problem mpich2
Date: Sun, 13 Feb 2011 02:02:27 +0200
hey guys,
i configured the mpich2 using mpd on my 2 nodes cluster
and all things r working great
but when i run an object file using either mpiexec or mpirun
it prints that there is no such file or directory
an error says as following:
>>let hello be the object file
problem with execution of hello on node1:[Errno 2] no such file or directory
same line repeats it self but instead of node1, there is node2
the number of lines differs as the number of process i state in the command
plz guys help me on that
regards,
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110213/21954b4d/attachment.htm>
