[mpich-discuss] Bug report system broken?
Rajeev Thakur thakur at mcs.anl.gov
Tue Feb 8 11:30:59 CST 2011
I was able to create a ticket ok. Make sure you provide your email address when creating the ticket.
Rajeev
On Feb 8, 2011, at 4:14 AM, Torquil Macdonald Sørensen wrote:
> Hi!
> It seems impossible to submit a bug report about MPICH2. I get the following error message:
> Trac detected an internal error:
> OperationalError: near "__FORM_TOKEN": syntax error
> It then proceeds to recommend submitting a bug report about the problem, but this only results in the same error message... So I'm submitting this here and hoping someone will fix the bug report system.
> I wanted to report two errors from the test suite run after building MPICH2 1.3.2. The two errors were:
> /home/tmac/src/mpich2-1.3.2/test/mpi/../..//bin/mpiexec -n 3  ./large_message
> [mpiexec at asus] ONE OF THE PROCESSES TERMINATED BADLY: CLEANING UP
> Unexpected output in large_message: [mpiexec at asus] ONE OF THE PROCESSES TERMINATED BADLY: CLEANING UP
> APPLICATION TERMINATED WITH THE EXIT STRING: Terminated (signal 15)
> Unexpected output in large_message: APPLICATION TERMINATED WITH THE EXIT STRING: Terminated (signal 15)
> Program large_message exited without No Errors
> and
> /home/tmac/src/mpich2-1.3.2/test/mpi/../..//bin/mpiexec -n 2  ./transp-datatype
> Transpose time with datatypes is more than twice time without datatypes
> Unexpected output in transp-datatype: Transpose time with datatypes is more than twice time without datatypes
> 0.000080	0.000018	0.000037
> Unexpected output in transp-datatype: 0.000080	0.000018	0.000037
> Found 1 errors
> Unexpected output in transp-datatype:  Found 1 errors
> My computer is an ASUS X5DID laptop with a dual core Intel T4400 CPU and 4GB RAM and 64bit architecture. It is running the Debian Sid OS, updated as of today, so I'm using the GCC 4.4.5 compilers. I'm not subscribed to this mailing list.
> Best regards
> Torquil Sørensen
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
