[mpich-discuss] Problem with spawning child with same executable name
Yauheni Zelenko zelenko at cadence.com
Fri Feb 4 15:46:21 CST 2011
Hi!
I'm trying to use MPI_Comm_spawn to run child process and then use MPI_Intercomm_merge. This steps works when spawned children have different executable name then parent process but failed on MPI_Intercomm_merge step if executable names are same.
Attached files could demonstrate a problem. Code is based on spawn_merge example.
If difference in executable names is requirement, will be good idea to include in into  MPI_Comm_spawn documentation. Otherwise it's bug.
Eugene.
Desc: Spawn.c
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110204/2a281c4a/attachment.obj>
Desc: SpawnChild.c
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110204/2a281c4a/attachment-0001.obj>
