[mpich-discuss] DataType Problem
Michele Rosso michele.rosso84 at gmail.com
Thu Feb 3 14:16:12 CST 2011
Thank you Ashley, that seems very promising!
I will try it!
Michele
-----Original Message-----
Reply-to: mpich-discuss at mcs.anl.gov
Subject: Re: [mpich-discuss] DataType Problem
Date: Thu, 3 Feb 2011 18:44:38 +0000
On 3 Feb 2011, at 18:24, Michele Rosso wrote:
> Then, I have no more problems. Thanks for your help.
> I got a final question: can you suggest me a good tutorial for parallel
> debugging? I know that a lot of people uses gdb(or ddd) for such purpose
> but I am not able to have it work. I do not need something powerful, but
> an easy tool just for simple checking of variables.
If it's a stack-based variable or function parameter then you could use padb, a link is in my signature.  Assuming you only have one parallel job running then the command line you want will be:
$ padb --stack-trace --tree -Ostack-shows-locals=1 -Ostack-shows-params=1 --all
If you have more than one job active then replace --all with the jobid.
Ashley.
