[mpich-discuss] mpd path
Pavan Balaji balaji at mcs.anl.gov
Wed Dec 28 02:24:50 CST 2011
Moving this to a different email thread.
MPD is no longer needed.  The mpd you are seeing in your path seems to
be from a different older installation of MPICH2, which can be ignored.
  With the new versions of MPICH2, you can directly use mpiexec without
having to launch MPD.  Usage instructions are provided here:
http://wiki.mcs.anl.gov/mpich2/index.php/Using_the_Hydra_Process_Manager
  -- Pavan
On 12/28/2011 02:19 AM, liu547479170 wrote:
> HI ,sir
> You suggest help me a lot ,thinks four you help !
> I was install my mpich2-1.4.1p1 like this
> ./configure --prefix=/usr/local/mpich2
> FC=/usr/local/intel/composer_xe_2011_sp1.7.256/bin/ia32/ifort
> F77=/usr/local/intel /composer_xe_2011_sp1.7.256/bin/ia32/ifortt
> CC=/usr/bin/gcc CXX=/usr/bin/g++
> make
> make install
> This all work well ,but when I do follows,
> which mpd
> which mpiexec
> which mpirun
> I get the result as follows
> /usr/local/intel/composer_xe_2011_sp1.7.256/mpirt/bin/ia32/mpd
> /usr/local/bin/ mpiexec
> /usr/local/bin/mpirun
> there are something different with the path that others provide ,other
> give the path that the above three path are /usr/local/bin/***
> So ,what is the matter of my soft ,what should i do to move my mpd into
> /usr/local/bin/mpd .
> By the way ,my OS is ubuntu 11.10 ,Intel fortran.
Pavan Balaji
http://www.mcs.anl.gov/~balaji
