[mpich-discuss] Hydra process manager on Condor
Pavan Balaji balaji at mcs.anl.gov
Tue Dec 27 00:01:27 CST 2011
Hydra does not understand Condor's parameters.  But you can emulate the
behavior you want by setting these options for mpiexec:
  -outfile-pattern ho.out -errfile-pattern he.err
You can also do more fancy things like:
  -outfile-pattern ho.%r.out -errfile-pattern he.%r.err
which uses different files for each rank.
See mpiexec -outfile-pattern -help for more information on other patterns.
  -- Pavan
On 12/19/2011 12:27 PM, Shrivastava, Savita wrote:
> Hi,
> We have installed MPICH2 with Hydra process manager on our Condor
> cluster. When I submit an mpi job to condor, the job is transferred to
> the execute node and executed properly (as I looked in the condor log on
> execute node where the job was executing) but it does not write the
> standard output from script to condor output file mentioned in job
> description file. Please guide me here how to run the mpi job
> successfully on condor using hydra process manager.
> My job description as below. The perl script has standard output "Hello".
> universe = parallel
> executable = /usr/lib64/mpich2/bin/mpiexec
> arguments = -n 2 -machinefile machinefile test2.pl
> getenv=true
> machine_count = 1
> should_transfer_files = yes
> when_to_transfer_output = on_exit
> transfer_input_files = test2.pl
> output = ho.out
> error = he.err
> log = hl.log
> Requirements = Memory >= 1024 && Cpus >=2
> request_cpus = 2
> request_memory = 1024
> queue
> Thanks
> Savita
> mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
> To manage subscription options or unsubscribe:
Pavan Balaji
http://www.mcs.anl.gov/~balaji
