[mpich-discuss] Hydra process manager on Condor
Shrivastava, Savita SShrivastava at path.wustl.edu
Mon Dec 19 12:27:48 CST 2011
We have installed MPICH2 with Hydra process manager on our Condor
cluster. When I submit an mpi job to condor, the job is transferred to
the execute node and executed properly (as I looked in the condor log on
execute node where the job was executing)  but it does not write the
standard output from script to condor output file mentioned in job
description file. Please guide me here how to run the mpi job
successfully on condor using hydra process manager.
My job description as below. The perl script has standard output
"Hello".
universe = parallel
executable = /usr/lib64/mpich2/bin/mpiexec
arguments = -n 2 -machinefile machinefile test2.pl
getenv=true
machine_count = 1
should_transfer_files = yes
when_to_transfer_output = on_exit
transfer_input_files = test2.pl
output = ho.out
error  = he.err
log    =  hl.log
Requirements = Memory >= 1024 && Cpus >=2
request_cpus = 2
request_memory = 1024
queue
Thanks
Savita
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111219/45eaa246/attachment.htm>
