[mpich-discuss] 64 bit application
Jayesh Krishna jayesh at mcs.anl.gov
Mon Dec 5 12:10:43 CST 2011
 Are you linking with the 64-bit libraries ?
 If you would like to compile 64-bit applications you need to install 64-bit version of MPICH2 and link your code with the libraries provided (Currently we don't provide 64-bit libs with 32-bit version of MPICH2 and vice versa. Due to limited dev bandwidth I am not sure if we might end up providing that in the near future.).
Jayesh
----- Original Message -----
From: "Marko Topalovic" <topalovic1981 at gmail.com>
Sent: Friday, December 2, 2011 9:03:20 AM
Subject: [mpich-discuss] 64 bit application
greetings
i am using windows7 64 bit and visual studio 2008
when i compile fpi from examples as Win32 application it works fine
when i change configuration to x64 it fails to compile giving me 20 errors
Error 1 error LNK2019: unresolved external symbol MPI_INIT referenced in function MAIN__ fpi.obj
this is linking problem but every setting in configuration is the same as for the Win32 application
so what should i do make this simple example work on x64 configuration
best regards,
Marko Topalovic
mpich-discuss mailing list     mpich-discuss at mcs.anl.gov
To manage subscription options or unsubscribe:
