[mpich-discuss] 64 bit application
Marko Topalovic topalovic1981 at gmail.com
Fri Dec 2 09:03:20 CST 2011
greetings
i am using windows7 64 bit and visual studio 2008
when i compile fpi from examples as Win32 application it works fine
when i change configuration to x64 it fails to compile giving me 20 errors
Error    1     error LNK2019: unresolved external symbol MPI_INIT
referenced in function MAIN__    fpi.obj
this is linking problem but every setting in configuration is the same as
for the Win32 application
so what should i do make this simple example work on x64 configuration
best regards,
Marko Topalovic
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20111202/6ec75a17/attachment.htm>
