[mpich-discuss] mpich2-1.3.2 cygwin build error.
Sunil Thomas sgthomas27 at gmail.com
Wed Apr 27 12:35:16 CDT 2011
Hi!
Thanks a lot for the response. I will try only disabling fortran support
first. Hopefully that works..
I would prefer to have shared library support if possible. What are my other
options on Windows if that's
the case and mpich2-1.3.2 does not support it with cygwin? Should I use
mngw? Is there any helpful
documentation on it that you have?
I need to build from source because the Windows pre-compiled binaries don't
come with the compilers
mpicc, mpicxx, etc. (atleast I have checked this from installing the
pre-compiled binaries on my
Windows machine previous to building from scratch) and I need these to
build my application using
MPI on cygwin...without which, as expected, I get the errors mpicc, mpicxx
not found, etc..
Thanks again,
--Sunil.
On Wed, Apr 27, 2011 at 8:27 AM, Jayesh Krishna <jayesh at mcs.anl.gov> wrote:
>  And if you don't need fortran support disable it (./configure ...
> --disable-f77 --disable-fc ).
> -Jayesh
>  ----- Original Message -----
> From: "Anthony Chan" <chan at mcs.anl.gov>
> To: mpich-discuss at mcs.anl.gov
> Sent: Wednesday, April 27, 2011 10:17:01 AM
> Subject: Re: [mpich-discuss] mpich2-1.3.2 cygwin build error.
> I am not sure cygwin shared library support is in 1.3.2p1. If you don't
> really
> need shared library support, you could remove configure option
> --enable-shared
> and see if things work OK.  You also don't need --enable-fast=O2 since -O2
> is
> the default.
> A.Chan
> > Hi!
> > My mpich2-1.3.2 cygwin build is failing (configure seems to complete
> > successfully
> > and I have done a make clean as instructed in the docs).
> > *make[4]: Leaving directory
> > `/tmp/sgthomas/mpich2-1.3.2p1/src/binding/f90'
> > make[4]: Entering directory
> > FC
> > /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/binding/f90/mpi.f90
> > make[4]: *** [mpi.lo] Error 1
> > make[3]: *** [all-redirect] Error 1
> > make[3]: Leaving directory
> > make[2]: *** [all-redirect] Error 1
> > make[2]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/binding'
> > make[1]: *** [all-redirect] Error 2
> > make[1]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src'
> > make: *** [all-redirect] Error 2*
> > I am testing this on 32 bit Windows 7. Attached is the c.txt and m.txt
> > files. I am
> > configuring this using:
> > configure --prefix=<path/to>install --enable-fast=O2 --enable-shared
> > |& tee
> > c.txt
> > make VERBOSE=1 2>&1 | tee m.txt
> > Any help to resolve this error is appreciated!
> > Thanks,
> > --Sunil.
> > _______________________________________________
> > mpich-discuss mailing list
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20110427/8e48a687/attachment.htm>
