[mpich-discuss] mpich2-1.3.2 cygwin build error.
Jayesh Krishna jayesh at mcs.anl.gov
Wed Apr 27 10:27:24 CDT 2011
 And if you don't need fortran support disable it (./configure ... --disable-f77 --disable-fc ).
-Jayesh
----- Original Message -----
Sent: Wednesday, April 27, 2011 10:17:01 AM
Subject: Re: [mpich-discuss] mpich2-1.3.2 cygwin build error.
I am not sure cygwin shared library support is in 1.3.2p1. If you don't really
need shared library support, you could remove configure option --enable-shared
and see if things work OK.  You also don't need --enable-fast=O2 since -O2 is
the default.
A.Chan
> Hi!
> My mpich2-1.3.2 cygwin build is failing (configure seems to complete
> successfully
> and I have done a make clean as instructed in the docs).
> *make[4]: Leaving directory
> `/tmp/sgthomas/mpich2-1.3.2p1/src/binding/f90'
> make[4]: Entering directory
> FC
> /cygdrive/c/Users/sgthomas/devl/mpich2-1.3.2p1/src/binding/f90/mpi.f90
> make[4]: *** [mpi.lo] Error 1
> make[3]: *** [all-redirect] Error 1
> make[3]: Leaving directory
> make[2]: *** [all-redirect] Error 1
> make[2]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src/binding'
> make[1]: *** [all-redirect] Error 2
> make[1]: Leaving directory `/tmp/sgthomas/mpich2-1.3.2p1/src'
> make: *** [all-redirect] Error 2*
> I am testing this on 32 bit Windows 7. Attached is the c.txt and m.txt
> files. I am
> configuring this using:
> configure --prefix=<path/to>install --enable-fast=O2 --enable-shared
> |& tee
> c.txt
> make VERBOSE=1 2>&1 | tee m.txt
> Any help to resolve this error is appreciated!
> Thanks,
> --Sunil.
> mpich-discuss mailing list
