[mpich-discuss] Profile library for MPICH2
Anthony Chan chan at mcs.anl.gov
Tue Apr 5 10:02:46 CDT 2011
----- Original Message -----
> This works fine for static library. Problem is with Shared one!
Where do you put your myconf.conf and your profiling library ?
what exact command did you use to link with your profiling library,
I assume it is something like "mpicc -profile=myprof -o foo foo.c",
right ?
A.Chan
> On Sun, Apr 3, 2011 at 8:35 AM, Anthony Chan <chan at mcs.anl.gov> wrote:
> > I think the mechanism should work shared library.
> > Can you provide more details what you are trying to achieve ?
> > A.Chan
> >> Hi!
> >> I am working on creating a profile library for MPICH2. version -
> >> "mpich2.1.3.2p1"
> >> I am using "-profile=myprof" option with "myprof.conf" file.
> >> I observed that this works only for static library. I could not
> >> make
> >> it work for shared library.
> >> Is it mandatory to have static library? It's bracause of some
> >> limitation or something? Or it is possible to use shared library
> >> but I
> >> went wrong somewhere?
> >> Thank you.
> >> Mandar Gurav
> >> http://www.mandargurav.org
> >> _______________________________________________
> >> mpich-discuss mailing list
> >> mpich-discuss at mcs.anl.gov
> >> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
> Mandar Gurav
