[mpich-discuss] Profile library for MPICH2
Mandar Gurav mandarwce at gmail.com
Tue Apr 5 04:17:28 CDT 2011
I have created a standard Shared libray using a general IDE such as Eclipse.
I am trying to create a profile library for my MPI programs.
the sample code is given below.
MPI_Send(....parameters....)
get the time here.
val = PMPI_Send(....parameters....)
get the time here.
return val;
You can refer to MPI 2.2 chapt 14.
This works fine for static library. Problem is with Shared one!
On Sun, Apr 3, 2011 at 8:35 AM, Anthony Chan <chan at mcs.anl.gov> wrote:
> I think the mechanism should work shared library.
> Can you provide more details what you are trying to achieve ?
> A.Chan
>> Hi!
>> I am working on creating a profile library for MPICH2. version -
>> "mpich2.1.3.2p1"
>> I am using "-profile=myprof" option with "myprof.conf" file.
>> I observed that this works only for static library. I could not make
>> it work for shared library.
>> Is it mandatory to have static library? It's bracause of some
>> limitation or something? Or it is possible to use shared library but I
>> went wrong somewhere?
>> Thank you.
>> Mandar Gurav
>> http://www.mandargurav.org
>> mpich-discuss mailing list
>> mpich-discuss at mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
Mandar Gurav
