[mpich-discuss] Conflict between MPICH2 and Microsoft SQL server
Angus Grandison A.J.Grandison at gre.ac.uk
Thu Oct 14 11:32:58 CDT 2010
  Hi Jayesh,
It is a problem with our collaborators system and this seems to have
fixed the issue by removing SQL server, unfortunately, I don't have
direct access to their system.  I was asking in the first instance if
this was a known issue and I guess from your response it isn't.  If this
hasn't been seen before then I'll need to investigate further myself and
it could well turn out to be unrelated to MPICH2.  It was MPICH2 1.2.1p1
and it was to do with loading a particular file which seems to take a
huge amount of time to load when SQL server is running.  I will let you
know if there are any pertinent developments on this front.
Thanks for your quick response,
Angus
On 14/10/2010 17:12, Jayesh Krishna wrote:
> Hi,
>>> We have some software which appears to run slowly...
>   Are you referring to MPICH2 ? Which version of MPICH2 are you using ? What kind of *slowness* do you see (How did you measure the *slowness* ? )?
> Regards,
> Jayesh
> From: "Angus Grandison"<A.J.Grandison at gre.ac.uk>
> To: mpich-discuss at mcs.anl.gov
> Sent: Thursday, October 14, 2010 10:45:03 AM GMT -06:00 US/Canada Central
> Subject: [mpich-discuss] Conflict between MPICH2 and Microsoft SQL server
>    We have some software which appears to run slowly when Microsoft SQL
> server is installed on a 64 bit Windows XP system.  Is this a known
> issue? Is there any workaround, apart from uninstalling Microsoft SQL
> server.
> Angus
_______________________________________________________________________
Dr Angus Grandison
Fire Safety Engineering Group
School of Computing and Mathematical Sciences
University of Greenwich
Old Royal Naval College
30 Park Row
Greenwich SE10 9LS
London
UK
web (group)    :   http://fseg.gre.ac.uk
web (personal) :   http://staffweb.cms.gre.ac.uk/~a.j.grandison/
mailto:A.J.Grandison at gre.ac.uk
Phone : +44 (0)20-8331-7912
Fax :   +44 (0)20-8331-8925
University of Greenwich, a charity and company limited by guarantee,
registered in England (reg no. 986729).  Registered Office: Old Royal
Naval College, Park Row, Greenwich SE10 9LS.
