[mpich-discuss] Windows 7 64 problems with credentials (tried many things)
Jim Hunziker jhunziker at bcisensors.com
Wed Oct 6 15:32:49 CDT 2010
No, it was the same number (2), but I did boot the VM with just 1 processor,
and there was no change in the problem.
Jim Hunziker
On Wed, Oct 6, 2010 at 4:22 PM, <jayesh at mcs.anl.gov> wrote:
> Hi,
>  Have you configured more logical processors on your VM than available on
> your host ?
> Regards,
> Jayesh
> From: "Jim Hunziker" <jhunziker at bcisensors.com>
> To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
> Sent: Tuesday, October 5, 2010 5:21:37 PM GMT -06:00 US/Canada Central
> Subject: Re: [mpich-discuss] Windows 7 64 problems with credentials (tried
> many things)
> Yes, I tried both of those things with no luck. Also, no virus scanner is
> running.
> Jim Hunziker
> On Oct 5, 2010 6:17 PM, "Jayesh Krishna" < jayesh at mcs.anl.gov > wrote:
> > Hi,
> > Do you have any firewalls running on the machine (Did you try turning the
> windows firewall off)? Did you try enabling only 1 processor on the machine
> > I will be able to access the VMs at our lab tomorrow and will update you
> on my findings.
> > Regards,
> > Jayesh
> > From: "Jim Hunziker" < jhunziker at bcisensors.com >
> > To: "Jayesh Krishna" < jayesh at mcs.anl.gov >
> > Sent: Tuesday, October 5, 2010 1:45:43 PM GMT -06:00 US/Canada Central
> (tried many things)
> > Attached is the log for the credentials / affinity problem.
> > Jim Hunziker
> > BCI Systems and Software Engineering
> > (973) 348-9299
> > On Tue, Oct 5, 2010 at 2:42 PM, Jayesh Krishna < jayesh at mcs.anl.gov >
> wrote:
> > Hi,
> > Can you send us the smpd log ?
> > Regards,
> > Jayesh
> > To: mpich-discuss at mcs.anl.gov
> > Sent: Tuesday, October 5, 2010 1:18:52 PM GMT -06:00 US/Canada Central
> > Subject: [mpich-discuss] Windows 7 64 problems with credentials (tried
> many things)
> > I'm getting "Credentials for JAHWIN7\jhunziker rejected connecting to
> jahwin7" messages in Windows 7 64-bit.
> > I installed the 64 bit version of 1.2.1p1, though I had the same problems
> with the 32 bit version. The installation was done with msiexec /i
> mpich2-1.2.1p1-win-x86-64.msi at an Administrator prompt. The installation
> was done for "Everyone".
> > As a regular user (who does have a password), I ran mpiexec -register to
> get my credentials in the registry. mpiexec -validate returns SUCCESS. I
> also did this step as a newly created user, in case there was something
> weird about my environment. The password is simple and alphanumeric.
> > When I use mpiexec to launch a program, it fails with the credential
> error. If I look in the Windows Event Viewer, I can see a successful login
> has been recorded.
> > If I run smpd -d to see the debug lines, there is an assertion failure in
> smpd_affinitize.c on line 157. I believe this an unrelated bug because
> mpiexec then fails with "op_read error on left context: Error = -1" rather
> than the credentials error. Since this failure is related to process
> affinity, I wonder if there's a problem relating to my using two processors
> in my machine, which is a VirtualBox virtual machine.
> > Any help would be greatly appreciated.
> > Jim Hunziker
> > _______________________________________________
> > mpich-discuss mailing list
> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20101006/f5a838e1/attachment.htm>
