[mpich-discuss] Windows 7 64 problems with credentials (tried many things)
jayesh at mcs.anl.gov jayesh at mcs.anl.gov
Wed Oct 6 15:22:36 CDT 2010
 Have you configured more logical processors on your VM than available on your host ?
Jayesh
----- Original Message -----
To: "Jayesh Krishna" <jayesh at mcs.anl.gov>
Sent: Tuesday, October 5, 2010 5:21:37 PM GMT -06:00 US/Canada Central
Subject: Re: [mpich-discuss] Windows 7 64 problems with credentials (tried many things)
Yes, I tried both of those things with no luck. Also, no virus scanner is running.
Jim Hunziker
On Oct 5, 2010 6:17 PM, "Jayesh Krishna" < jayesh at mcs.anl.gov > wrote:
> Hi,
> Do you have any firewalls running on the machine (Did you try turning the windows firewall off)? Did you try enabling only 1 processor on the machine ?
> I will be able to access the VMs at our lab tomorrow and will update you on my findings.
> Regards,
> Jayesh
> From: "Jim Hunziker" < jhunziker at bcisensors.com >
> To: "Jayesh Krishna" < jayesh at mcs.anl.gov >
> Sent: Tuesday, October 5, 2010 1:45:43 PM GMT -06:00 US/Canada Central
> Attached is the log for the credentials / affinity problem.
> Jim Hunziker
> BCI Systems and Software Engineering
> (973) 348-9299
> On Tue, Oct 5, 2010 at 2:42 PM, Jayesh Krishna < jayesh at mcs.anl.gov > wrote:
> Hi,
> Can you send us the smpd log ?
> Regards,
> Jayesh
> To: mpich-discuss at mcs.anl.gov
> Sent: Tuesday, October 5, 2010 1:18:52 PM GMT -06:00 US/Canada Central
> Subject: [mpich-discuss] Windows 7 64 problems with credentials (tried many things)
> I'm getting "Credentials for JAHWIN7\jhunziker rejected connecting to jahwin7" messages in Windows 7 64-bit.
> I installed the 64 bit version of 1.2.1p1, though I had the same problems with the 32 bit version. The installation was done with msiexec /i mpich2-1.2.1p1-win-x86-64.msi at an Administrator prompt. The installation was done for "Everyone".
> As a regular user (who does have a password), I ran mpiexec -register to get my credentials in the registry. mpiexec -validate returns SUCCESS. I also did this step as a newly created user, in case there was something weird about my environment. The password is simple and alphanumeric.
> When I use mpiexec to launch a program, it fails with the credential error. If I look in the Windows Event Viewer, I can see a successful login has been recorded.
> If I run smpd -d to see the debug lines, there is an assertion failure in smpd_affinitize.c on line 157. I believe this an unrelated bug because mpiexec then fails with "op_read error on left context: Error = -1" rather than the credentials error. Since this failure is related to process affinity, I wonder if there's a problem relating to my using two processors in my machine, which is a VirtualBox virtual machine.
> Any help would be greatly appreciated.
> Jim Hunziker
> mpich-discuss mailing list
