[mpich-discuss] query on MPICH2 on Windows
Kunal Rao kunalgrao at gmail.com
Sat Oct 2 18:11:07 CDT 2010
Hi
 I was able to configure and build the parallel netcdf library on Windows
using the cygwin environment and MPICH2 as the MPI implementation. I still
have to check if this library works with the application that I am trying to
link it to.
Here are the steps that I have followed:
a) Downloaded the MPICH2 source code (1.2.1p1) from
http://www.mcs.anl.gov/research/projects/mpich2/
b) Did the regular configure/make/make install steps in the cygwin
environment in Windows.
    ( set C compiler as gcc and Fortran compiler as gfortran)
c) Downloaded parallel netcdf (parallel-netcdf-1.2.0.tar.gz)  from
http://trac.mcs.anl.gov/projects/parallel-netcdf/wiki/Download
d) Again, did the regular configure/make/make install steps for parallel
netcdf in cygwin environment in Windows and used the previously built MPICH2
as the mpi implementation ( for the --with-mpi option)
The steps went fine and the libpnetcdf.a library has been built on Windows
through the cygwin environment. I will next check if this links properly and
works with the application.
Thanks & Regards,
Kunal
On Sat, Oct 2, 2010 at 2:49 PM, Jayesh Krishna <jayesh at mcs.anl.gov> wrote:
> Hi,
>  As Rob mentioned the error might be due to the way netcdf checks for
> MPI-IO support.
>  Can you give us details on how you configure netcdf with MPICH2 ?
> (PS: MPI-IO is available with MPICH2 on windows even if you use the
> installers for your installation.)
> Regards,
> Jayesh
> From: "Kunal Rao" <kunalgrao at gmail.com>
> To: mpich-discuss at mcs.anl.gov
> Sent: Saturday, October 2, 2010 12:08:52 PM GMT -06:00 US/Canada Central
> Subject: Re: [mpich-discuss] query on MPICH2 on Windows
> Hi
> Initially, I had used the installers availabe at the MPICH 2 website and
> that was giving the error mentioned before. I then, downloaded
> the source code and built MPICH2 from that (configure/make/make install) in
> cygwin and linked this MPI while configuring parallel
> netcdf. Now, it is not giving that error and it moved ahead.
> Thanks & Regards,
> Kunal
> On Fri, Oct 1, 2010 at 8:18 PM, Jayesh Krishna < jayesh at mcs.anl.gov >
> wrote:
> Hi,
> Did you build MPICH2 from source (configure/make/make install) under cygwin
> environment ? Or did you install MPICH2 using installers available at the
> MPICH2 website ?
> Regards,
> Jayesh
> From: "Kunal Rao" < kunalgrao at gmail.com >
> Sent: Friday, October 1, 2010 5:01:38 PM GMT -06:00 US/Canada Central
> Subject: [mpich-discuss] query on MPICH2 on Windows
> Hi
> Does MPICH2 on Microsoft Windows support MPI-IO ?
> I was checking on this site
> http://www.mcs.anl.gov/research/projects/romio/ where it says that ROMIO
> is included as a part of MPICH 2.
> The reason I ask this is because I am trying to configure parallel netcdf
> library on Windows through the cygwin environment. While doing "configure"
> it stops with the following message:
> checking MPI-IO support in MPI implementation... configure: error: mpi
> implementation does not support MPI-IO
> The MPI implementation I used is MPICH2 which I was assuming supported
> MPI-IO on Windows as well. I tried using MSMPI but even that stopped with
> the same message. Any thoughts on this ?
> Thanks & Regards,
> Kunal
> mpich-discuss mailing list
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20101002/ad23f73d/attachment.htm>
