[mpich-discuss] query on MPICH2 on Windows
Jayesh Krishna jayesh at mcs.anl.gov
Sat Oct 2 13:49:43 CDT 2010
 As Rob mentioned the error might be due to the way netcdf checks for MPI-IO support.
 Can you give us details on how you configure netcdf with MPICH2 ?
(PS: MPI-IO is available with MPICH2 on windows even if you use the installers for your installation.)
Jayesh
----- Original Message -----
Sent: Saturday, October 2, 2010 12:08:52 PM GMT -06:00 US/Canada Central
Subject: Re: [mpich-discuss] query on MPICH2 on Windows
Hi
Initially, I had used the installers availabe at the MPICH 2 website and that was giving the error mentioned before. I then, downloaded
the source code and built MPICH2 from that (configure/make/make install) in cygwin and linked this MPI while configuring parallel
netcdf. Now, it is not giving that error and it moved ahead.
Thanks & Regards,
Kunal
On Fri, Oct 1, 2010 at 8:18 PM, Jayesh Krishna < jayesh at mcs.anl.gov > wrote:
Did you build MPICH2 from source (configure/make/make install) under cygwin environment ? Or did you install MPICH2 using installers available at the MPICH2 website ?
Jayesh
Sent: Friday, October 1, 2010 5:01:38 PM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] query on MPICH2 on Windows
Hi
Does MPICH2 on Microsoft Windows support MPI-IO ?
I was checking on this site http://www.mcs.anl.gov/research/projects/romio/ where it says that ROMIO is included as a part of MPICH 2.
The reason I ask this is because I am trying to configure parallel netcdf library on Windows through the cygwin environment. While doing "configure" it stops with the following message:
checking MPI-IO support in MPI implementation... configure: error: mpi implementation does not support MPI-IO
The MPI implementation I used is MPICH2 which I was assuming supported MPI-IO on Windows as well. I tried using MSMPI but even that stopped with the same message. Any thoughts on this ?
Thanks & Regards,
Kunal
mpich-discuss mailing list
