[mpich-discuss] query on MPICH2 on Windows
Jayesh Krishna jayesh at mcs.anl.gov
Fri Oct 1 19:18:54 CDT 2010
 Did you build MPICH2 from source (configure/make/make install) under cygwin environment ? Or did you install MPICH2 using installers available at the MPICH2 website ?
Jayesh
----- Original Message -----
Sent: Friday, October 1, 2010 5:01:38 PM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] query on MPICH2 on Windows
Hi
Does MPICH2 on Microsoft Windows support MPI-IO ?
I was checking on this site http://www.mcs.anl.gov/research/projects/romio/ where it says that ROMIO is included as a part of MPICH 2.
The reason I ask this is because I am trying to configure parallel netcdf library on Windows through the cygwin environment. While doing "configure" it stops with the following message:
checking MPI-IO support in MPI implementation... configure: error: mpi implementation does not support MPI-IO
The MPI implementation I used is MPICH2 which I was assuming supported MPI-IO on Windows as well. I tried using MSMPI but even that stopped with the same message. Any thoughts on this ?
Thanks & Regards,
Kunal
mpich-discuss mailing list
