[mpich-discuss] query on MPICH2 on Windows
Kunal Rao kunalgrao at gmail.com
Fri Oct 1 17:01:38 CDT 2010
Hi
  Does MPICH2 on Microsoft Windows support MPI-IO ?
  I was checking on this site
http://www.mcs.anl.gov/research/projects/romio/ where it says that ROMIO is
included as a part of MPICH 2.
  The reason I ask this is because I am trying to configure parallel netcdf
library on Windows through the cygwin environment. While doing "configure"
it stops with the following message:
  checking MPI-IO support in MPI implementation... configure: error: mpi
implementation does not support MPI-IO
  The MPI implementation I used is MPICH2 which I was assuming supported
MPI-IO on Windows as well. I tried using MSMPI but even that stopped with
the same message. Any thoughts on this ?
Thanks & Regards,
Kunal
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20101001/6696e565/attachment.htm>
