[mpich-discuss] mpi test error
Anthony Chan chan at mcs.anl.gov
Fri Nov 19 09:57:01 CST 2010
MPICH2-1.0 is ancient.  Can you try the latest mpich2 release, 1.3.1, instead
and see if the error is still there ?
----- Original Message -----
> Hi, all
> The version is mpich2-1.0, and when I run a program encounter a
> problem as below:
> *** Caught a fatal signal: SIGSEGV(11) on node 0/2
> NOTICE: Before reporting bugs, run with GASNET_BACKTRACE=1 in the
> environment to generate a backtrace.
> aborting job:
> Fatal error in MPI_Test: Other MPI error, error stack:
> MPI_Test(152): MPI_Test(request=0x1127cd00, flag=0x7fff9c4d307c,
> status=0x7fff9c4d3480) failed
> MPIDI_CH3_Progress_test(111): an error occurred while handling an
> event returned by MPIDU_Sock_Wait()
> MPIDI_CH3I_Progress_handle_sock_event(492):
> connection_recv_fail(1728):
> MPIDU_Socki_handle_read(590): connection closed by peer (set=0,sock=1)
> rank 0 in job 277 node66_48638 caused collective abort of all ranks
> exit status of rank 0: killed by signal 11
> Any advice is welcome!
> Thanks!
> Eric
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
