[mpich-discuss] mpi test error
eirc.lew eirc.lew at gmail.com
Thu Nov 18 23:06:51 CST 2010
Hi, all
  The version is mpich2-1.0, and when I run a program encounter a problem as below:
*** Caught a fatal signal: SIGSEGV(11) on node 0/2
NOTICE: Before reporting bugs, run with GASNET_BACKTRACE=1 in the environment to generate a backtrace.
aborting job:
Fatal error in MPI_Test: Other MPI error, error stack:
MPI_Test(152): MPI_Test(request=0x1127cd00, flag=0x7fff9c4d307c, status=0x7fff9c4d3480) failed
MPIDI_CH3_Progress_test(111): an error occurred while handling an event returned by MPIDU_Sock_Wait()
MPIDI_CH3I_Progress_handle_sock_event(492):
connection_recv_fail(1728):
MPIDU_Socki_handle_read(590): connection closed by peer (set=0,sock=1)
rank 0 in job 277  node66_48638   caused collective abort of all ranks
  exit status of rank 0: killed by signal 11
Any advice is welcome!
Thanks!
Eric
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20101119/c7f9d879/attachment.htm>
