[mpich-discuss] configure: different behaviour for bitypes.h on two machines
Anthony Chan chan at mcs.anl.gov
Thu Jan 29 11:53:36 CST 2009
----- "Siegmar Gross" <Siegmar.Gross at informatik.fh-fulda.de> wrote:
> configure:23487: checking for sys/bitypes.h
> configure:23508:   conftest.c
> configure:23515: $? = 0
> configure:23562: result: yes
I believe the bug has been fixed in our repository about 2 months ago.
Here is what happens as far as I can remember:
For some reasons, configure.in somehow eats up the check for C preprocessor,
so C preprocessor is undefined before the tests of all header files,
that get us to the line 23508 that configure tries to execute
a text file conftest.c.  Normally, the system (i.e. any unix hosts)
would emit an error when executing a text file.  But Cygwin's default
bourne-like shell returns OK when running conftest.c, hence wrong result
for the header file.  We have since added a explicit check for C preprocessor
and replaced the old test for headers with a modern/robust one,
problem seems to go away.
A.Chan
