[mpich-discuss] MPICH v1.2.7p1 and SMP clusters
chong tan chong_guan_tan at yahoo.com
Tue Jan 13 16:50:17 CST 2009
Since I don't know how parallalism is explored in your application, I have to assume that inter-process communication is not a crtitical factor (based on your run result).
Back to HW.  1 CPU with 2 cores !== 2CPU with 1 core in terms of performance.
With 2 boxes, your aggreated memory bandwidth is larger.  Cache bandwidth can also be better on 2 boxes. Therefore you maybe get better throughput frrom 2 boxes of 2X2 by running 1 job per CPU.  The older version of Linux (I assume you have this) may not be able to distribute job evenly per physical CPU, the later ones do a reasonably good job on this, hhowever.
As a way to convince yourselves, would you mind try the following experiment :
1.  use taskset to run 2 copy of your non-MPI application, first on the same CPU
2. repeat the last step, but on different physical CPUs
if you want to see how the total available resource is affecting perforamnce, do :
3.  run 4 copies of your non MPI applicatino on one box.
hopefully, the perforamnce you derived can tell you something.  Otherwise, MPICH2 has have some serious bug.
tan
--- On Tue, 1/13/09, Marcus Vinicius Brandão Soares <mvbsoares at gmail.com> wrote:
From: Marcus Vinicius Brandão Soares <mvbsoares at gmail.com>
Subject: Re: [mpich-discuss] MPICH v1.2.7p1 and SMP clusters
Date: Tuesday, January 13, 2009, 2:04 PM
Hello Gustavo,
My point is: depending on the structure of the connections (the edges of the graph) that are used interconnecting the processors and the type of processsing (cpu intensive or communication intensive) and, even, the level of paralelism (much sequential to divide-and-conquer) it may be easy to explain the differences you made reference to.
Do you agree ?
Best regards,
2009/1/13 Gustavo Miranda Teixeira <magusbr at gmail.com>
Hello Marcus,
I can't see what your point is. Do you want to know in which core is the processes allocated? Like if it's on the same processor or different ones?
On Tue, Jan 13, 2009 at 3:06 PM, Marcus Vinicius Brandão Soares <mvbsoares at gmail.com> wrote:
Hello Gustavo and all,
You described that you are using two machines with a dual processor in each one. If I can model it in a simple graph, we have two vertices and two unidirectional edges.
Each machine has a dual processor, each one with dual core, so there are 8 processor. But lets think again in the graph model: now we have two vertices, each one with two more vertices; these last two vertices have two more vertices too, and so this is the end.
Do you know the structure of the communication lines of the core processors ?
Hello everyone!
I've been experiencing some issues when using MPICH v1.2.7p1 and a SMP cluster and thought maybe some one can help me here.
I have a small cluster with two dual processor machines with gigabit ethernet communication. Each processor is a dual core which sums up to 8 cores of processors. When I run an application spreading 4 processes in both the machines (like distributing 2 processes in one machine and 2 processes in another) I get a significantly better performance than when I run the same application using 4 processes in only one machine. Isn`t it a bit curious? I know some people who also noticed that, but no one can explain me why this happens. Googling it didn't helped either. I originally thought it was a problem from my kind of application (a heart simulator which using PETSc to solve some differential equations) but some simple experimentations showed a simple MPI_Send inside a huge loop causes the same issue. Measuring cache hits and misses showed it`s not a memory contention problem. I also know that a in-node communication in MPICH uses the loopback interface, but
 as far as I know a message that uses loopback interface simply takes a shortcut to the input queue instead of being sent to the device, so there is no reason for the message to take longer to get to the other processes. So, I have no idea why it`s taking longer to use MPICH in the same machine. Does anyone else have noticed that too? Is there some logical explanation for this to happen?
Marcus Vinicius
"Havendo suficientes colaboradores,
Qualquer problema é passível de solução"
Eric S. Raymond
A Catedral e o Bazar
"O passado é apenas um recurso para o presente"
Clave de Clau
"Ninguém é tão pobre que não possa dar um abraço; e
Ninguém é tão rico que não necessite de um abraço.
Anônimo
Marcus Vinicius
Eric S. Raymond
Clave de Clau
Anônimo
URL: <http://lists.mcs.anl.gov/pipermail/mpich-discuss/attachments/20090113/bb3617dc/attachment.htm>
