[mpich-discuss] -mpe=mpitrace not producing any output, and Valgrind outputs on r3717
James S Perrin james.s.perrin at manchester.ac.uk
Wed Jan 7 11:13:02 CST 2009
Anthony Chan wrote:
> Does your code use any MPI-2 features, like connect/accept or
> comm_spawn or even put/get ?  Did you try -mpe=mpilog ?
Uses MPI I/O.
Yes I've used -mpe=mpilog successfully, I was just going through the
options.
>> However if this option is equivalent the the MPE -mpitrace option
>> http://www-unix.mcs.anl.gov/mpi/mpich1/docs/mpeman/node7.htm#Node8
>> should it also be printing out some accumulated times as well?
> I look up some really old versions of trc_wrappers.c in MPICH1 and I don't
> see it has any statistics collection code in it.  My guess is that the
> MPICH1 documentation was never updated.  BTW, if you need simple statistics,
> you could use FPMPI2 at http://www.mcs.anl.gov/fpmpi
> (the latest version about 1 year old)
Ok, thanks.
Regards
James
   James S. Perrin
   Visualization
   Research Computing Services
   Devonshire House, University Precinct
   The University of Manchester
   Oxford Road, Manchester, M13 9PL
   t: +44 (0) 161 275 6945
   e: james.perrin at manchester.ac.uk
   w: www.manchester.ac.uk/researchcomputing
  "The test of intellect is the refusal to belabour the obvious"
  - Alfred Bester
