[mpich-discuss] MPICH2 v.1.2.1 build error; -Switch case constants must be unique
Dave Goodell goodell at mcs.anl.gov
Fri Dec 11 18:41:14 CST 2009
Hi Ray,
It sounds like you have found a bug in our optional type handling
code, specifically with respect to the new C99 complex types that were
added for MPI-2.2 support.  What version of the PGI compilers are you
using?
In order to figure out what's really going on here, I'll need to take
a look at your config.log.  Would you please file a bug report for
this at:
http://trac.mcs.anl.gov/projects/mpich2/newticket
and attach your config.log to the new ticket?
In the very short term, you should hopefully be able to get around
this problem by deleting lines 200-211 from src/mpi/coll/oputil.h
(reproduced below for clarity).
-Dave
--------8<--------
    200	#if defined(HAVE_FLOAT__COMPLEX)
    201	#  undef MPIR_OP_TYPE_MACRO_HAVE_C_FLOAT_COMPLEX
    202	#  define
MPIR_OP_TYPE_MACRO_HAVE_C_FLOAT_COMPLEX(mpi_type_,c_type_)
MPIR_OP_C_COMPLEX_TYPE_MACRO(mpi_type_,c_type_)
    203	#endif
    204	#if defined(HAVE_DOUBLE__COMPLEX)
    205	#  undef MPIR_OP_TYPE_MACRO_HAVE_C_DOUBLE_COMPLEX
    206	#  define
MPIR_OP_TYPE_MACRO_HAVE_C_DOUBLE_COMPLEX(mpi_type_,c_type_)
    207	#endif
    208	#if defined(HAVE_LONG_DOUBLE__COMPLEX)
    209	#  undef MPIR_OP_TYPE_MACRO_HAVE_C_LONG_DOUBLE_COMPLEX
    210	#  define
MPIR_OP_TYPE_MACRO_HAVE_C_LONG_DOUBLE_COMPLEX(mpi_type_,c_type_)
    211	#endif
--------8<--------
On Dec 11, 2009, at 3:09 PM, Ray Sheppard wrote:
> Hi,
>  I have run into some trouble.  Orginally, I hit this error using
> pgf90
> and pgcc to build MPICH on an Intel based cluster:
> PGC-S-0083-Switch case constants must be unique (opsum.c: 57)
> PGC-S-0083-Switch case constants must be unique (opsum.c: 94)
> This turned out to be using: MPIR_OP_TYPE_GROUP() for both (COMPLEX)
> and
> (COMPLEX_EXTRA).  So, I just thought I would comment out the
> (COMPLEX_EXTRA) line and see what happens. What happened is that the
> package stumbles again in opprod.c.  I have not yet found an
> explanation or a fix in your documentation.  So, I am writing to ask
> how I can make it work.  Thanks.
>                                        Ray
>                         Respectfully,
>                           Ray Sheppard
>                           RSheppar at indiana.edu
>                           http://rac.uits.iu.edu/hpc/
>                           317-274-0016
>                   Principal Analyst
>                   High Performance Applications
>                   Research Technologies
>                   University Information Technological Services
>                   IUPUI campus
>                   Indiana University
>         My "pithy" saying since everyone has one these days:
>             5 tons phytoplankton = 1 pound fish.
>             -- Please help protect the environment.
> mpich-discuss mailing list
> mpich-discuss at mcs.anl.gov
