[mpich-discuss] Fwd: Fatal error in MPI_Recv: Error message texts are not available
Jayesh Krishna jayesh at mcs.anl.gov
Wed Dec 9 09:13:42 CST 2009
 Good to know MPICH2 works for you now. Let us know if you need any help.
Jayesh
----- Original Message -----
Sent: Tuesday, December 8, 2009 4:57:29 PM GMT -06:00 US/Canada Central
Subject: Re: [mpich-discuss] Fwd: Fatal error in MPI_Recv: Error message texts are not available
Hi
I made a mistake. I compiled my software with one version of MPICH2 and i was trying to run it with other version.
Problem Solved
2009/12/8 Jayesh Krishna < jayesh at mcs.anl.gov >
FYI...
----- Forwarded Message -----
To: "Jayesh Krishna" < jayesh at mcs.anl.gov >
Sent: Tuesday, December 8, 2009 2:58:10 PM GMT -06:00 US/Canada Central
Subject: Re: [mpich-discuss] Fatal error in MPI_Recv: Error message texts are not available
I'm using mpich2 1.1 in rocks linux.
Recently we added to myrinet boards to our cluster, before that we didn't had any problems and thread level provided by mpich2 was MPI_THREAD_MULTIPLE.
If i try to run the job in the machine that has no myrinet ( 4 cores ) it runs without problem, although the thread level is still MPI_THREAD_SERIALIZED.
Thanks
Are you using MPICH2 on windows (If so, did you try running your job with the multithreaded sock channel or the nemesis channel, eg: mpiexec -n 2 -channel mt my_multithreaded_sw.exe )?
Jayesh
Sent: Tuesday, December 8, 2009 2:02:30 PM GMT -06:00 US/Canada Central
Subject: [mpich-discuss] Fatal error in MPI_Recv: Error message texts are not available
Hi
I'm trying to run a mpi multithreaded software, but i'm getting this error on MPI_Recv in one of the threads:
"Fatal error in MPI_Recv: Error message texts are not available"
Anyone knows a possible cause to this problem?
Could it be becouse mpich2 just provides thread level MPI_THREAD_SERIALIZED?
Luís Miranda
mpich-discuss mailing list
Luís Miranda
Luís Miranda
