[mpich-discuss] MPI_File_sync and MPI_File_set_size
    Wei-keng Liao
    wkliao at ece.northwestern.edu
    Wed Dec  9 01:35:58 CST 2009
In ROMIO, when the hint romio_no_indep_rw is set to true,
only the IO aggregators open/read/write/close the file.
In MPI_File_sync, ADIOI_TEST_DEFERRED() is called before
ADIO_Flush(), to check if the file is opened, which forces
all non-aggregators to open the file. I think it is not
necessary. A simple check for open status can fix this, eg.
   if ( (fh)->is_open ) ADIO_Flush(fh, &error_code);
Also, the similar issue happens for MPI_File_set_size().
The current implementation lets aggregator 0 to call
ftruncate() and then broadcast the result to all processes.
It is also not necessary to call ADIOI_TEST_DEFERRED().
The fix is simply remove the call.
Wei-keng
