[mpich-discuss] running job using ipoib through mpirun_rsh
Pavan Balaji balaji at mcs.anl.gov
Tue Dec 1 22:56:30 CST 2009
Devesh,
Are you running MPICH2-1.0.8p1 on top of IPoIB or MVAPICH2?
If you have IB, you should really use it natively, instead of going
through TCP/IP (IPoIB). You can download MVAPICH2 for this.
If you still need to use MPICH2 over IPoIB, you should download the
latest version of MPICH2 (1.2.1) and use the Hydra process manager
instead (mpiexec.hydra instead of mpiexec).
 -- Pavan
On 12/01/2009 10:48 PM, Devesh Sharma wrote:
> hello all, thanks for your responses.
> I forgot to mention that I am trying to run my job using
> MPICH2-nemesis ADI (1.0.8p1).
> On Tue, Dec 1, 2009 at 10:19 PM, Dhabaleswar Panda
> <panda at cse.ohio-state.edu> wrote:
>> Using mpirun_rsh for IPoIB interface is not supported currently. The
>> TCP/IP interface supported in MVAPICH2 package is the same as MPICH2.
>> Thus, you need to use the job launching mechanism, as supported by MPICH2,
>> for running applications using IPoIB interface.  You can use mpirun_rsh
> So, with MPICH2 also I will have to use mpd.
>> for all other interfaces (Gen2-IB, iWARP, PSM, RDMAoE, etc.).
>> Hope this helps.
>> Thanks,
>> DK
>> On Tue, 1 Dec 2009 chan at mcs.anl.gov wrote:
>>> Since this is a MVAPICH question, cc'ed this to mvapich-discuss.
>>> A.Chan
>>> ----- "Devesh Sharma" <devesh28 at gmail.com> wrote:
>>>> Hello list,
>>>> I am trying to run a job over a large cluster over IPoIB interface
>>>> but
>>>> it is failing.
>>>> How can I start the job using mpirun_rsh? does the hostfile specified
>>>> via -hostfile have format similar to what is used in MVAPICH2 while
>>>> running jobs
>>>> using ssm ADI over IPoIB?
>>>> -regards
>>>> Devesh
>>>> _______________________________________________
>>>> mpich-discuss mailing list
>>>> mpich-discuss at mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
Pavan Balaji
http://www.mcs.anl.gov/~balaji
