[mpich-discuss] running job using ipoib through mpirun_rsh
Devesh Sharma devesh28 at gmail.com
Tue Dec 1 22:48:24 CST 2009
hello all, thanks for your responses.
I forgot to mention that I am trying to run my job using
MPICH2-nemesis ADI (1.0.8p1).
On Tue, Dec 1, 2009 at 10:19 PM, Dhabaleswar Panda
<panda at cse.ohio-state.edu> wrote:
> Using mpirun_rsh for IPoIB interface is not supported currently. The
> TCP/IP interface supported in MVAPICH2 package is the same as MPICH2.
> Thus, you need to use the job launching mechanism, as supported by MPICH2,
> for running applications using IPoIB interface.  You can use mpirun_rsh
So, with MPICH2 also I will have to use mpd.
> for all other interfaces (Gen2-IB, iWARP, PSM, RDMAoE, etc.).
> Hope this helps.
> Thanks,
> DK
> On Tue, 1 Dec 2009 chan at mcs.anl.gov wrote:
>> Since this is a MVAPICH question, cc'ed this to mvapich-discuss.
>> A.Chan
>> ----- "Devesh Sharma" <devesh28 at gmail.com> wrote:
>> > Hello list,
>> > I am trying to run a job over a large cluster over IPoIB interface
>> > but
>> > it is failing.
>> > How can I start the job using mpirun_rsh? does the hostfile specified
>> > via -hostfile have format similar to what is used in MVAPICH2 while
>> > running jobs
>> > using ssm ADI over IPoIB?
>> > -regards
>> > Devesh
>> > _______________________________________________
>> > mpich-discuss mailing list
>> > mpich-discuss at mcs.anl.gov
>> > https://lists.mcs.anl.gov/mailman/listinfo/mpich-discuss
