[MPICH] Fatal error in MPI_Init using ch3:sock or ch3:ssm
Rajeev Thakur thakur at mcs.anl.gov
Fri Jun 1 08:32:50 CDT 2007
Then your code should work. Just make sure you have compiled all files with
the right mpicc.
Rajeev
> -----Original Message-----
> From: owner-mpich-discuss at mcs.anl.gov
> [mailto:owner-mpich-discuss at mcs.anl.gov] On Behalf Of Romain Dolbeau
> Sent: Friday, June 01, 2007 2:27 AM
> To: mpich-discuss at mcs.anl.gov
> Cc: 'Romain Dolbeau'
> Subject: Re: [MPICH] Fatal error in MPI_Init using ch3:sock or ch3:ssm
> Rajeev Thakur wrote:
> > If you run "make testing" in the top-level mpich2
> directory, it will run the
> > entire test suite in test/mpi. Do all those tests pass?
> In test/mpi, as far as I can tell yes, everything seems
> to be fine.
> Only in test/commands can I see errors (./stdintest2).
> Thanks for your answer,
> Romain Dolbeau
