[MPICH] Fatal error in MPI_Init using ch3:sock or ch3:ssm
Romain Dolbeau romain at dolbeau.org
Fri Jun 1 02:27:17 CDT 2007
Rajeev Thakur wrote:
> If you run "make testing" in the top-level mpich2 directory, it will run the
> entire test suite in test/mpi. Do all those tests pass?
In test/mpi, as far as I can tell yes, everything seems
to be fine.
Only in test/commands can I see errors (./stdintest2).
Thanks for your answer,
Romain Dolbeau
