[MPICH] MPICH2 and PVFS2
Peter Diamessis pjd38 at cornell.edu
Fri Apr 13 13:46:58 CDT 2007
Hi Rob,
Actually, one more thing. I did contact our system admin. .
He says he'll install MPICH2 but is concerned as to whether
it supports MX ? The cluster is currently set-up using GM but
they are transitioning to MX and his understanding of your email
is that MX is not supported by MPICH2 ? Thus, open-MPI may
the cluster's ultimate option ?
Any thoughts here ?
Sincerely,
Peter Diamessis
----- Original Message -----
To: "Peter Diamessis" <pjd38 at cornell.edu>
Cc: <mpich-discuss at mcs.anl.gov>
Sent: Friday, April 13, 2007 12:21 PM
Subject: Re: [MPICH] MPICH2 and PVFS2
> On Thu, Apr 12, 2007 at 11:51:27PM -0400, Peter Diamessis wrote:
>> Apparently, MPICH v1.2.7..15 is still being used at the cluster. Our system
>> manager has made an effort to build it to make ROMIO compatible with
>> PVFS2. Nonetheless, my problems persist. Would it simply be a better
>> idea that they shift the whole cluster to MPICH2, which I assume is more
>> naturally compatible with PVFS2 ?
> Hi Peter
> First, I'm glad you're using MPI-IO to its full potential and seeing
> good results.
> Second, yes, the PVFS v2 support in MPICH 1.2.7 is quite old: about 2
> years of bugfixes have gone into MPICH2-1.0.5p4.  It'd be great if you
> could run MPICH2 -- you might still find bugs but particularly for
> noncontiguous I/O we have fixed a number of issues.
> Now, complicating the matter is that v1.2.7..15 is a version of MPICH
> for the myrinet interconnect.  Your admin will know know if you are
> using GM or MX.  Let your administrator know you can build MPICH2 with
> gm support by configuring MPICH2 with the --with-device=ch3:nemesis:gm
> flag.  You might also need --with-gm-include=/path/to/include/gm  if
> your GM headers are in a different location.
>> Sorry if I sound too ignorant but my I/O troubles have driven me up the
>> wall.
> This is not an ignorant question at all.  Thanks for sending in the
> report instead of just quitting in frustration.
> ==rob
> Rob Latham
> Mathematics and Computer Science Division    A215 0178 EA2D B059 8CDF
> Argonne National Lab, IL USA                 B29D F333 664A 4280 315B
