[POOL] Final results
Bass, Dean Allen
bass at anl.gov
Wed Apr 27 10:11:02 CDT 2016
The final week of the season is over. Congratulation to Team #7 No Sweat who won the Play Off championship.
I think the Periscope broadcast test went well. We have 4 matches that were broadcast and they were all well watched both live and after that fact. I do have to watch auto correct as when I listed the Candido vs Jim match, it changed Candido’s name to a disease. But otherwise, I know Rick had some family members tuned in from different parts of the country as did I. We’ll see how it goes again in the fall.
There have been a few proposed rule changes which we’ll discuss with captains in the fall. For your consideration:
1. Change rule of losing team puts up next player to alternating putting up next player.
2. Create a greater advantage for high handicap differential between players. For example differential > 130 either:
a. Allow for one “pinch hitter” in match or
b. Allow player the option to make the 8 Ball before the last of their last ball is pocketed.
3. Modify the playoff to give a higher finish to a team that goes 2-1 than a team that goes 1-2.
Tentative start up date will be Sept 20 which should make the final week for the fall December 20. I’ll try to send out a notice in late August to remind every one and to see what teams need players. Have a great summer and keep practicing.
Name: Final Playoff Bracket (PDF).pdf
Type: application/pdf
Desc: Final Playoff Bracket (PDF).pdf
URL: <http://lists.mcs.anl.gov/pipermail/mcs-pool/attachments/20160427/84970e2a/attachment-0002.pdf>
Name: Results Spring 2016 Week 17 (PDF).pdf
Desc: Results Spring 2016 Week 17 (PDF).pdf
URL: <http://lists.mcs.anl.gov/pipermail/mcs-pool/attachments/20160427/84970e2a/attachment-0003.pdf>
More information about the mcs-pool
