[hpc-announce] [CC2024] Call for Participation for the ACM SIGPLAN 2024 International Conference on Compiler Construction
Gabriel Rodríguez Álvarez gabriel.rodriguez at udc.es
Thu Jan 25 03:11:37 CST 2024
ACM SIGPLAN 2024 International Conference on Compiler Construction (CC'24)
co-located with CGO, PPoPP and HPCA
Edinburgh, Scotland, UK
March 2 - 3, 2024
https://conf.researchr.org/home/CC-2024
The International Conference on Compiler Construction (CC) is interested in work on processing programs in the most general sense: analyzing, transforming or executing input that describes how a system operates, including traditional compiler construction as a special case.
CC 2024 is the 33rd edition of the conference. CC is an ACM SIGPLAN conference and implements guidelines and procedures recommended by SIGPLAN https://www.sigplan.org.
IMPORTANT INFORMATION
Early registration : 2     February 2024
Conference         : 2-3   March    2024
CC 2024 will be held at the Edinburgh International Conference Center in Scotland, UK, and is co-located with CGO, PPoPP, and HPCA. Any person registering for CC can attend any of the co-located workshops.
Register for the conference at https://inconference.eventsair.com/ieee--acm-2024/cc-registration.
PROGRAM
- If-Convert as Early as You Must, Dorit Nuzman, Ayal Zaks, Ziv Ben-Zion
- Paguroidea: Fused Parser Generator with Transparent Semantic Actions, Yifan Zhu, Quartic Cat, Boluo Ge, Shaotong Sun
- Compiler-based Memory Encryption for Machine Learning on Commodity Low-power Devices, Kiwan Maeng, Brandon Lucia
- UNIFICO: Thread Migration in Heterogeneous-ISA CPUs without State Transformation, Nikolaos Mavrogeorgis, Christos Vasiladiotis, Pei Mu, Amir Khordadi, Björn Franke, Antonio Barbalace
- YFlows: Systematic Dataflow Exploration and Code Generation for Efficient Neural Network Inference using SIMD Architectures on CPUs, Cyrus Zhou, Zack Hassman, Dhirpal Shah, Vaughn Richard, Yanjing Li
- Fast Template-Based Code Generation for MLIR, Florian Drescher, Alexis Engelke
- BLQ: Light-Weight Locality-Aware Runtime for Blocking-Less Queuing, Qinzhe Wu, Ruihao Li, Jonathan Beard, Lizy John
- Reducing the Overhead of Exact Profiling by Reusing Affine Variables, Leon Frenot, Fernando Magno Quintao Pereira
- From low-level fault modeling (of a pipeline attack) to a proven hardening scheme, Sébastien Michelland, Laure Gonnord, Christophe Deleuze
- Region-Based Data Layout via Data Reuse Analysis, Caio Salvador Rohwedder, José Nelson Amaral
- Fast and Accurate Context-Aware Basic Block Timing Prediction using Transformers, Abderaouf Nassim AMALOU, Elisa Fromont, Isabelle Puaut
- Stale Profile Matching, Amir Ayupov, Maksim Panchenko, Sergey Pupyrev
- A Context-Sensitive Pointer Analysis Framework for Rust and its Application to Call Graph Construction, Wei Li, Yujiang Gui, Wenguang Chen, Jingling Xue
- APPy: Annotated Parallelism for Python on GPUs, Tong Zhou, Jun Shirako, Vivek Sarkar
- CoSense: Compiler Optimizations using Sensor Technical Specifications, Pei Mu, Nikolaos Mavrogeorgis, Christos Vasiladiotis, Vasileios Tsoutsouras, Orestis Kaparounakis, Phillip Stanley-Marbell, Antonio Barbalace
- FlowProf: Profiling Multi-threaded Programs using Information-Flow, Ahamed Al Nahian, Brian Demsky
- Accurate coverage metrics for compiler-generated debugging information, J. Ryan Stinnett, Stephen Kell
- Clog: A Declarative Language for C Static Code Checkers, Alexandru Dura, Christoph Reichenbach
- The Next 700 ML-Enabled Compiler Optimizations, S. VenkataKeerthy, Siddharth Jain, Umesh Kalvakuntla, Pranav Sai Gorantla, Rajiv Shailesh Chitale, Eugene Brevdo, Albert Cohen, Mircea Trofin, Ramakrishna Upadrasta
- A Unified Memory Dependency Framework for Speculative High-Level Synthesis, Jean-Michel Gorius, Simon Rokicki, Steven Derrien
- Exponentially Expanding the Phase-Ordering Search Space via Dormant Information, Ruobing Han, Hyesoon Kim
SPONSORS
Platinum
Huawei - https://huawei.com/
Gold
Amazon - https://www.amazon.com/
Ant Research - https://www.antgroup.com/en
CodePlay - https://www.codeplay.com
Silver
ARM - https://www.arm.com/
FuriosaAI - https://www.furiosa.ai/
Google - https://www.google.com/
Rebellions - https://rebellions.ai/
Bronze
AMD - https://www.amd.com/
IBM - https://www.ibm.com/
MangoBoost - https://mangoboost.io/
Moreh - https://www.moreh.io/
Qualcomm - https://www.qualcomm.com/
ACM SIGPLAN                     https://www.sigplan.org
Raincode Labs                   https://www.raincodelabs.com/
ORGANIZERS
General Chair
Gabriel Rodriguez - Universidade da Coruña
Program Co-Chairs
Saday Sadayappan - University of Utah
Aravind Sukumaran Rajam - Meta
Artifact Evaluation Chair
Martin Kong - The Ohio State University
Sponsorship Chair
EunJung Park - Qualcomm
Web Chair
Roberto Lopez Castro - Universidade da Coruña
Steering Committee
Louis-Noel Pouchet - Colorado State University
Delphine Demange - Univ Rennes, INRIA, CNRS, IRISA
Bernhard Egger - Seoul National University
Rajiv Gupta - UC Riverside
Alexandra Jimborean - University of Murcia
Ondrej Lhotak - University of Waterloo
Xipeng Shen - North Carolina State University
Aaron Smith - Microsoft
Clark Verbrugge - McGill University
More information about the hpc-announce mailing list
