[hpc-announce] HPDC 2024: Call for Papers (Main Track)
Maria Fazio mfazio at unime.it
Wed Nov 15 01:45:25 CST 2023
Date: 3-7 June 2024
Web Site: https://www.hpdc.org/2024/
The ACM International Symposium on High-Performance Parallel and
Distributed Computing (HPDC) is the premier annual conference for
presenting the latest research on the design, implementation,
evaluation, and use of parallel and distributed systems for high-end
computing. The 33rd HPDC will take place in Pisa, Italy, June 3-7, 2024.
* Deadlines
Abstracts due: January 18th 11:59pm Anywhere on Earth (AoE), 2024
Papers due: January 25th 11:59pm Anywhere on Earth (AoE), 2024
Author notifications: March 25th, 2024
Camera-ready version: April 18th, 2024
Conference dates: June 3-7, 2024
* Scope and Topics
Submissions are welcomed on high-performance parallel and distributed
computing (HPDC) topics including but not limited to: clouds, clusters,
grids, big data, massively multicore, and extreme-scale computing
systems. Experience reports of operational deployments that provide
significantly novel insights for future research on HPDC applications
and systems are also welcome.
In the context of high-performance parallel and distributed computing,
the topics of interest include, but are not limited to:
-Datacenter, HPC, cloud, serverless, and edge/IoT computing platforms
-Heterogeneous computing accelerators and non-volatile memory systems
-File and storage systems, I/O, and data management
-Operating systems and networks
-System software and middleware for parallel and distributed systems
-Programming languages and runtime systems
-Big data stacks and big data ecosystems
-Scientific applications, algorithms, and workflows
-Resource management and scheduling
-Performance modeling, benchmarking, and engineering
-Fault tolerance, reliability, and availability
-Operational guarantees, risk assessment, and management
-Novel post-Moore computing technologies including neuromorphic,
brain-inspired computing, and quantum computing.
* Paper Submission Categories
Submissions to HPDC can be made in one of the following two categories:
(1) regular papers, or (2) open-source tools and data papers. The
primary focus of regular papers should be to describe new research ideas
supported by experimental implementation and evaluation of the proposed
research ideas. The primary focus of open-source tools and data should
be to describe the design, development, and evaluation of new
open-source tools or novel data sources. Submissions in the regular
papers category are also strongly encouraged to open-source their
software or hardware artifacts.
The authors are required to indicate the category of the paper as a part
of the submitted manuscript's title. The last line of the title should
indicate the paper type by using one of the two phrases (1) Paper Type:
Regular, or (2) Paper Type: Open-source tools and data paper.
Submissions in both categories will be evaluated to the same standards
in terms of novelty, scientific value, demonstrated usefulness, and
potential impact on the field.  The chosen category at the time of the
submission can not be changed after the submission deadline.
* Submission Guidelines
Authors are invited to submit technical papers of at most 11 pages in
PDF format, excluding references. Accepted papers will have the
flexibility to use an additional page in the camera-ready to incorporate
feedback from the reviewers. Papers should be formatted in the ACM
Proceedings Style and submitted via the conference submission website.
Submitted papers must be original work that has not appeared in and is
not under consideration for another conference or a journal.
* Anonymizing Submissions
HPDC uses double-blind reviewing. Avoid identifying yourself or your
institution explicitly or by implication (e.g., through the references
or acknowledgments). The first page should use the paper ID assigned
during registration in place of the author names.
Use care in referring to your own related work. Do not omit references
to your prior work, as this would make it difficult for reviewers to
place your submission in its proper context. Instead, reference your
past work in the third person, just as you would any other piece of
related work. In some cases, it is not credible to refer to your related
work in the third person. For example, your submission may extend a
previous workshop paper, or it may relate to a submission currently
under review at HPDC or another venue. In these cases, you must still
explain the differences between your HPDC submission and the other work,
but you should cite the other work anonymously and e-mail the
deanonymized work to the PC chairs.
If your submission reports on experiences with a system at your
institution, you should refer to the system anonymously but describe the
properties of the system that are needed to evaluate the work (e.g.,
size of the user base, volume of requests, etc.). We recognize that, in
some cases, these properties may allow a reviewer to identify your
institution.  Tool/data papers should also adhere to the double-blind
submission policy. If the described tool/dataset framework is already
widely used by the research community, consider describing the framework
using a different name and not sharing the open-source code repository
in the paper.
* Confidential Information
Papers containing information that is subject to a non-disclosure
agreement (NDA) will not be considered for review.
* arXiv Submission Policy
Please note that having an arXiv paper does not prohibit authors from
submitting a paper to HPDC 2024. arXiv papers are not peer-reviewed and
not considered as formal publications and hence do not count as prior
work. Authors are not expected to compare against arXiv papers that have
not formally appeared in previous conference or journal proceedings. If
a submitted paper is already on arXiv, please continue to follow the
double-blind submission guidelines. Authors are encouraged to use
preventive measures to reduce the chances of accidental breach of
anonymity (e.g., use a different title in the submission and do not
upload/revise the arXiv version during the review period after the
submission deadline).
* Author List After Acceptance
Please note that the author list cannot be changed after acceptance.
* Conflict of Interest Declaration
At the time of submission, all authors must indicate their conflict of
interest with the PC members. A conflict of interest may be
institutional, collaborative, or personal. Please see detailed
guidelines about how to accurately declare a conflict of interest on the
submission website.
* ACM Policy on Authorship
Please refer to the ACM Policy on Authorship for all other guidelines.
The frequently asked questions page
(https://www.acm.org/publications/policies/frequently-asked-questions)
provides policies on the use of generative AI tools in preparing
manuscripts.
By submitting your article to an ACM Publication, you are hereby
acknowledging that you and your co-authors are subject to all ACM
Publications Policies, including ACM's new Publications Policy on
Research Involving Human Participants and Subjects. Alleged violations
of this policy or any ACM Publications Policy will be investigated by
ACM and may result in a full retraction of your paper, in addition to
other potential penalties, as per ACM Publications Policy.
Please ensure that you and your co-authors obtain an ORCID ID, so you
can complete the publishing process for your accepted paper. ACM has
been involved in ORCID from the start and we have recently made a
commitment to collect ORCID IDs from all of our published authors.  The
collection process has started and will roll out as a requirement
throughout 2022.  We are committed to improve author discoverability,
ensure proper attribution and contribute to ongoing community efforts
around name normalization; your ORCID ID will help in these efforts.
* Contact PC Chairs
David Lowenthal (dkl at cs.arizona.edu)
Rosa M Badia (rosa.m.badia at bsc.es)
* Submissions
Submissions are now open at https://hpdc24.hotcrp.com/.
* Suggestions for Document Preparation for Authors
-Formatting the Introduction Section
HPDC authors are encouraged to structure their introduction section of
the paper in the following format (as subsections or headings).
I. Motivation. Clearly state the objective of the paper and provide
(quantitative) support to motivate the specific problem your submission
is solving.
II. Limitation of state-of-art approaches. Briefly review the most
relevant and most recent prior works. Clearly articulate the limitations
of prior works and how your approach breaks away from those limitations.
A more detailed discussion should be reserved for the related work
section. But, this section should be sufficient to help readers
recognize the novelty of your approach.
III. Key insights and contributions. Briefly articulate the major
insights that enable your approach or make it effective. Clearly specify
the novelty of these insights and how they advance state-of-the-art.
Describe the key ideas of your approach and design. List the key
contributions including flagship empirical results and improvement over
the prior art as applicable.
IV. Experimental methodology and artifact availability. Clearly specify
the key experimental / simulation infrastructure and methodological
details. Support the experimental methodology choices (e.g., cite that
most relevant and most recent prior works have evaluated their ideas
using similar methodology). Include a line to indicate whether the
software/hardware artifact will be available upon acceptance.
V. Limitations of the proposed approach. Almost all scientific
contributions have limitations and scope for improvement. Clearly
articulate all the major limitations of the proposed approach and
identify conclusions that are sensitive to specific assumptions made in
the paper.
Please note this suggested format is not a requirement for submission,
and authors will not be penalized for using a different format.
-Ethical Considerations
If your research describes a new security-related attack, please
consider adding information about the responsible disclosure to the
relevant entity. Overall, as appropriate and relevant, the paper should
follow the ethical principles and not alter the
security/privacy/equality expectations of the associated human users.
-Inclusive Description of Research Contributions
Please consider making your research contribution description inclusive
in nature. For example, consider using gender-neutral pronouns, consider
using examples that are ethnicity/culture-rich, consider engaging users
from diverse backgrounds if your research involves a survey, etc. Best
efforts should be made to make the paper accessible to visually impaired
or color-blind readers.
More information about the hpc-announce mailing list
