[Darshan-users] HDF5 chunking and Darshan with enable-hdf5-mod results in error
Tobias Meisel tobias.meisel at ufz.de
Mon Apr 19 07:17:44 CDT 2021
Hi all,
I’ve built 3.2.1 Darshan with --enable-hdf5-mod=
When I began writing chunks collectively with hdf5 I got errors only when darshan
instrumentation is enabled.
The darshan instrumentation without hdf5 chunking worked fine (also with --enable-hdf5-
mod).
I have opened a topic at the HDF group forum: https://forum.hdfgroup.org/t/parallel-hdf5-write-with-irregular-size-in-one-dimension/8284/5
The resulting errors are posted to this topic as well.
The minimal example to reproduce the error is also here: https://dbkt.hdfgroup.org/
original/2X/c/c58be4df192333b6d15d6e91d58b114b85cea2f4.cc
My Setup is:
     *  OpenMPI (OpenRTE) 4.0.5
     *  HDF5 1.12.0
     *  Darshan 3.2.1
Could you take a look and check if there is a problem with the HDF5 instrumentation in
Darshan?
Thank you
Tobias
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20210419/89dbd82d/attachment.html>
More information about the Darshan-users mailing list
