[Darshan-users] Trouble building shared parallel hdf5 library on BGQ, trying to use w Darshan
Hedges, Richard M. hedges1 at llnl.gov
Tue Jan 12 11:25:30 CST 2016
I am trying to apply Darshan to a dynamically linked executable on a BGQ system with shared parallel hdf5 library.  I have tried several Darshan versions, several hdf5 versions, and am using the gcc C and fortran compilers (with mlicc and mpif90 wrappers)
Without Darshan, the code will execute, but when set LD_PRELOAD, the code aborts.  My suspicion is that there is a problem with my hdf5 library build.
Has anyone encountered this?
Does anyone have a good (and current)recipe for building parallel hdf5 on BGQ?
- Richard
Richard Hedges
Customer Support and Test - File Systems Project
Development Environment Group - Livermore Computing
Lawrence Livermore National Laboratory
7000 East Avenue, MS L-557
Livermore, CA    94551
v:    (925) 423-2699
f:    (925) 423-6961
E:    richard-hedges at llnl.gov
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20160112/37b7b977/attachment.html>
More information about the Darshan-users mailing list
