[AG-TECH] Fwd: Accessgrid Error Certificate
Thomas Uram
turam at mcs.anl.gov
Thu Apr 7 18:01:01 CDT 2011
Hello:
A workaround for this problem is now detailed in the following bug report:
https://bugzilla.mcs.anl.gov/accessgrid/show_bug.cgi?id=1928
We are investigating a more formal solution to this problem.
Tom
On Mar 29, 2011, at 1:36 AM, <ada1 at uma.es> wrote:
> Greetings from Malaga University
> last few days we can not access to "venue management tool" to the
> configuration of multicast. Running "Venue Server" in debug mode shows the
> error "SSLError: TLSv1 alert unknow ca".
> We have requested a new certificate type "service", we've installed it and
> the error is the same (NOTE: we have requested the certificate as "service" type, but once is installed changes to "identity" type. Is it normal?)
> Do you think we have to try deleting all certificates and re-requesting an "identity" (not "service" type this time) certificate instead of? In any case we have requested a identity certificate for probing it. If no is a problem we'll contact you again for help if the error exists
> How many certificates are recomendable to have installed? With one is sufficient? Is a problem to have installed two or more valid certificates?
> Screen capture attached.
> Thanks for your dedication with us.
> <Capture_SSLError_tlsv1_alert_unknown_ca.bmp>
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20110407/9bb42182/attachment.htm>
