[AG-TECH] VPCscreen behaviour
Philippe d'Anfray
Philippe.d-Anfray at cea.fr
Tue Mar 30 10:30:02 CDT 2010
Andrew Rowley a écrit :
> Yes, the ttl looks like the culprit. Are you sure that -t is the correct way to set the ttl in VPCScreen?
This is what "VPCScreenCapture -h" tells us. There is no way to fix
the TTL through the AG Client Interface
(VPCScreenCapture is called with -t 127) may be this value is not used
and some substitute (16) is hard coded
somewhere ?
Bonne soirée
Philippe
VPCScreen by the ANU Internet Futures team
Usage: VPCScreenCapture [-h] [-K <str>] [-c <str>] [-N <str>] [-T <str>]
[-E <str>] [-L <str>] [-P <str>] [-A <str>] [-b <num>] [-f <num>] [-s
<str>] [-q <num>] [-t <num>] [-m] destination (address/port)
-h, --help Show help
-K, --key=<str> Set the encryption key for sending
-c, --codec=<str> Set the codec to use for sending
-N, --name=<str> SDES name
-T, --note=<str> SDES note
-E, --email=<str> SDES email
-L, --location=<str> SDES location
-P, --phone=<str> SDES phone
-A, --appsite=<str> APP specific site
-b, --bandwidth=<num> Bandwidth in bits per second
-f, --framerate=<num> Frame rate in frames per second
-s, --size=<str> Specify fixed size either CIF or PAL for
-q, --quality=<num> Specify quality of encoding (1 -- 100)
-t, --ttl=<num> TTL for multicast transmission
-m, --minimize Start the interface minimized
Type: text/x-vcard
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20100330/b7dc94e3/attachment.vcf>
