[AG-TECH] VPCscreen behaviour
Andrew Rowley
Andrew.Rowley at manchester.ac.uk
Tue Mar 30 10:22:07 CDT 2010
Yes, the ttl looks like the culprit. Are you sure that -t is the correct way to set the ttl in VPCScreen?
Andrew :)
Andrew G D Rowley
Senior Development Officer
Research Computing Services
The University of Manchester
Devonshire House, Oxford Road
Manchester, M13 9PL
t : +44 (0) 161 275 0685
e : Andrew.Rowley at manchester.ac.uk
w : www.manchester.ac.uk/researchcomputing
> -----Original Message-----
> From: ag-tech-bounces at lists.mcs.anl.gov [mailto:ag-tech-
> bounces at lists.mcs.anl.gov] On Behalf Of Philippe d'Anfray
> Sent: 30 March 2010 16:00
> To: ag-tech at mcs.anl.gov
> Subject: Re: [AG-TECH] VPCscreen behaviour
> Andrew Rowley a écrit :
> > 1) Can you run a wireshark
> > 2) The network people are unlikely
> > 3) Can I also check that vic (I assume it is vic you are using to
> transmit video) and VPCScreen are running on the same multicast address
> and port?
> > 4) A summary of your problem is that multicast appears to be working (as
> attested to by the working video transmission and reception) but VPCScreen
> specifically doesn't seem to be getting out of the machine. Is this
> correct?
> Bonjour,
> 4) Yes exactly !!!
> 1) Hum! it seems that "in fine" TTL is only set to 16 ? (see capture)
> and according to this Tutorial,
> http://ntrg.cs.tcd.ie/undergrad/4ba2/multicast/antony/ it is normal
> that we are restricted to "our site"
> > As the values of the TTL field increase, routers will expand the
> > number of hops they will forward a multicast packet. To provide
> > meaningful scope control, multicast routers enforce the following
> > "thresholds" on forwarding based on the TTL field:
> > *0*
> > restricted to the same host
> > *1*
> > restricted to the same subnet
> > *32*
> > restricted to the same site
> > *64*
> > restricted to the same region
> > *128*
> > restricted to the same continent
> > *255*
> > unrestricted
> This might be the solution, we just have to find how 127 becomes 16.... ?
> Cordialement
> Philippe
> 2) Yes of course. We use UBUNTU boxes that we installed ourselves so we
> know what's inside I just checked for a "strange rule" in our site
> firewall...
> 3) If I start VPCscreen and a Video producer service I have the same
> addres/port (and TTL)
> /usr/bin/VPCScreenCapture ...... -t 127 224.2.141.24/61520
> vic ...........-t 127 224.2.141.24/61520
