[AG-TECH] IDS Falcon
Christoph Willing
c.willing at uq.edu.au
Mon Mar 9 19:33:01 CDT 2009
On 10/03/2009, at 4:23 AM, Todd Zimmerman wrote:
> On Mon, 2009-03-09 at 14:36 +0100, Marcolino PIRES wrote:
>> Hi,
>> Thank you for your post.
>> But we still have problems with our IDS quattro card.
>> May be could you help us a little more...
>> As you we finally choose bttv module.
>> I try several tests with vlc but only get a bleu screen...
>> We are under ubuntu 8.10 here follows the modules of our used
>> modules :
>> root at aristotest4:~# lsmod |grep btt
>> bttv 171028 1 bt878
>> videodev 41344 1 bttv
>> i2c_algo_bit 14340 1 bttv
>> v4l2_common 19840 1 bttv
>> videobuf_dma_sg 20612 1 bttv
>> videobuf_core 26628 2 bttv,videobuf_dma_sg
>> btcx_risc 12552 1 bttv
>> tveeprom 20228 1 bttv
>> ir_common 48900 1 bttv
>> compat_ioctl32 9344 1 bttv
>> i2c_core 31892 5
>> bttv,i2c_algo_bit,v4l2_common,tveeprom,nvidia
>> I also use v4l2-ctl expecting some parameter will solve the problem
>> but
>> it was unsuccessful !
>> Best regards...
> Hi Marcolino,
> I'm forwarding your email to the Global ag-tech mailing list.
> Perhaps someone on that list would be able to help.
Marcolino,
With a supported video card on Ubuntu 8.10, I can run:
vlc v4l2://dev/video0
If that doesn't work for you, check that your card is recognised -
have a look at the output of the following commands in a shell:
lspci -v
and
ls -l /dev/video*
I would also check that you have valid video going into the card - can
you confirm this by running any other video capture applications e.g.
vic from the AG toolkit (where you'll also have better control over
capture parameters)?
BTW, I found that changing any settings in the capture menu of vlc's
user interface resulted in the video disappearing - vic is much better
for this type of testing.
chris
Christoph Willing +61 7 3365 8316
QCIF Access Grid Manager
University of Queensland
