[AG-TECH] IDS Falcon
Todd Zimmerman
todd.zimmerman at ubc.ca
Mon Mar 9 13:23:32 CDT 2009
On Mon, 2009-03-09 at 14:36 +0100, Marcolino PIRES wrote:
> Hi,
> Thank you for your post.
> But we still have problems with our IDS quattro card.
> May be could you help us a little more...
> As you we finally choose bttv module.
> I try several tests with vlc but only get a bleu screen...
> We are under ubuntu 8.10 here follows the modules of our used modules :
> root at aristotest4:~# lsmod |grep btt
> bttv 171028 1 bt878
> videodev 41344 1 bttv
> i2c_algo_bit 14340 1 bttv
> v4l2_common 19840 1 bttv
> videobuf_dma_sg 20612 1 bttv
> videobuf_core 26628 2 bttv,videobuf_dma_sg
> btcx_risc 12552 1 bttv
> tveeprom 20228 1 bttv
> ir_common 48900 1 bttv
> compat_ioctl32 9344 1 bttv
> i2c_core 31892 5
> bttv,i2c_algo_bit,v4l2_common,tveeprom,nvidia
> I also use v4l2-ctl expecting some parameter will solve the problem but
> it was unsuccessful !
> Best regards...
Hi Marcolino,
I'm forwarding your email to the Global ag-tech mailing list.
Perhaps someone on that list would be able to help.
Cheers,
Todd
