[AG-TECH] Possible problems with the 3.2 Beta "all-in-one-installer"!
Andrew Ford
acf0659 at rit.edu
Mon Mar 9 15:52:55 CDT 2009
Yeah, I already added Piers - I'm subscribing to sumover-dev now.
--Andrew
2009/3/9 Thomas D. Uram <turam at mcs.anl.gov>
> Andrew:
> You should also copy at least piers, if not the sumover-dev list
> Tom
> On 3/9/09 3:45 PM, Andrew Ford wrote:
> Jason,
> At least one of the machines I was looking at had never had 3.2 installed,
> so I'm pretty sure that it's the compile option issue that Tom mentioned. To
> confirm I guess we'd have to check with whoever does the H264 and 3.2
> Windows packaging.
> Tom,
> I'm sending you a lengthy email about compilation issues, since I'm not
> sure how much ag-tech cares about how annoying ffmpeg is :)
> --Andrew
> 2009/3/8 Jason Bell <j.bell at cqu.edu.au>
>> Andrew
>> Did you happen to install the “3.2 all-in-one-installer” first? I found I
>> had to delete the “C:\Documents and Settings\[username]\Application
>> Data\AccessGrid3” directory and then use 3.1 and it worked fine!
>> Try using the 3.1 all in one installer and see if that helps???
>> Cheers,
>> Jason.
>> *From:* Andrew Ford [mailto:acf0659 at rit.edu]
>> *Sent:* Saturday, 7 March 2009 5:21 AM
>> *To:* Jason Bell
>> *Cc:* ag-tech at mcs.anl.gov; accessgrid-l at clix.aarnet.edu.au;
>> AG-Tech-NZ at googlegroups.com
>> *Subject:* Re: [AG-TECH] Possible problems with the 3.2 Beta
>> Hi Jason,
>> We've been seeing the same problems with not being able to receive h261as
>> streams, except that we have AG 3.1 on all of our Windows machines. Our Macs
>> can see 261as streams just fine. Has anyone else tried 261as on Windows?
>> --Andrew
>> 2009/3/3 Jason Bell <j.bell at cqu.edu.au>
>> G'day All (Apologies for any cross posting)
>> I was wondering if anyone has had any issues with the AG 3.2 Beta "all in
>> one installer" lately?
>> Upon recent testing, last couple of days, I have noticed 2 issues:
>> · VenueVNC not working and users having to follow the instructions
>> found at http://www.accessgrid.org/node/1031
>> · Video* Services not displaying H261AS video Streams… When Using
>> VPCScreen, sending a window using H261AS, others are able to see the video
>> streams, but it is completely missing from an AG 3.2 Beta "all in one
>> install". Note, if you use 3.1 "all in one install", it works fine.
>> What is interesting is that it is completely missing, ie, not even a grey
>> thumbnail or the likes can be seen.
>> Has anyone else seen similar issues?
>> Nathan, any chance of investigating these issues and repackaging the “all
>> in one installer”???
>> Thanks,
>> Jason.
>> Jason Bell, B.I.T. (Honours)
>> Research Systems Support Officer
>> Information Technology Division
>> CQ University Australia
>> Australian Research Collaboration Service
>> http://www.arcs.org.au/
>> E-mail : j.bell at cqu.edu.au
>> jason.bell at arcs.org.au
>> Work : +61 7 4930 9229
>> Mobile : 0409 630897
>> Postal : Building 19
>> Central Queensland University
>> Bruce Highway
>> Rockhampton, Queensland, Australia, 4702
>> Patience is a virtue.
>> But if I wanted Patience,
>> I would have become a Doctor.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20090309/524717bb/attachment-0001.htm>
