[AG-TECH] Possible problems with the 3.2 Beta "all-in-one-installer"!
Thomas D. Uram
turam at mcs.anl.gov
Mon Mar 9 15:47:40 CDT 2009
Andrew:
You should also copy at least piers, if not the sumover-dev list
Tom
On 3/9/09 3:45 PM, Andrew Ford wrote:
> Jason,
> At least one of the machines I was looking at had never had 3.2
> installed, so I'm pretty sure that it's the compile option issue that
> Tom mentioned. To confirm I guess we'd have to check with whoever does
> the H264 and 3.2 Windows packaging.
> Tom,
> I'm sending you a lengthy email about compilation issues, since I'm
> not sure how much ag-tech cares about how annoying ffmpeg is :)
> --Andrew
> 2009/3/8 Jason Bell <j.bell at cqu.edu.au <mailto:j.bell at cqu.edu.au>>
> Andrew
> Did you happen to install the “3.2 all-in-one-installer” first? I
> found I had to delete the “C:\Documents and
> Settings\[username]\Application Data\AccessGrid3” directory and
> then use 3.1 and it worked fine!
> Try using the 3.1 all in one installer and see if that helps???
> Cheers,
> Jason.
> *From:* Andrew Ford [mailto:acf0659 at rit.edu <mailto:acf0659 at rit.edu>]
> *Sent:* Saturday, 7 March 2009 5:21 AM
> *To:* Jason Bell
> *Cc:* ag-tech at mcs.anl.gov <mailto:ag-tech at mcs.anl.gov>;
> accessgrid-l at clix.aarnet.edu.au
> <mailto:accessgrid-l at clix.aarnet.edu.au>;
> AG-Tech-NZ at googlegroups.com <mailto:AG-Tech-NZ at googlegroups.com>
> *Subject:* Re: [AG-TECH] Possible problems with the 3.2 Beta
> Hi Jason,
> We've been seeing the same problems with not being able to receive
> h261as streams, except that we have AG 3.1 on all of our Windows
> machines. Our Macs can see 261as streams just fine. Has anyone
> else tried 261as on Windows?
> --Andrew
> 2009/3/3 Jason Bell <j.bell at cqu.edu.au <mailto:j.bell at cqu.edu.au>>
> G'day All (Apologies for any cross posting)
> I was wondering if anyone has had any issues with the AG 3.2 Beta
> "all in one installer" lately?
> Upon recent testing, last couple of days, I have noticed 2 issues:
> · VenueVNC not working and users having to follow the
> instructions found at http://www.accessgrid.org/node/1031
> · Video* Services not displaying H261AS video Streams… When
> Using VPCScreen, sending a window using H261AS, others are able to
> see the video streams, but it is completely missing from an AG 3.2
> Beta "all in one install". Note, if you use 3.1 "all in one
> install", it works fine. What is interesting is that it is
> completely missing, ie, not even a grey thumbnail or the likes can
> be seen.
> Has anyone else seen similar issues?
> Nathan, any chance of investigating these issues and repackaging
> the “all in one installer”???
> Thanks,
> Jason.
> Jason Bell, B.I.T. (Honours)
> Research Systems Support Officer
> Information Technology Division
> CQ University Australia
> Australian Research Collaboration Service
> http://www.arcs.org.au/
> E-mail : j.bell at cqu.edu.au <mailto:j.bell at cqu.edu.au>
> jason.bell at arcs.org.au <mailto:jason.bell at arcs.org.au>
> Work : +61 7 4930 9229
> Mobile : 0409 630897
> Postal : Building 19
> Central Queensland University
> Bruce Highway
> Rockhampton, Queensland, Australia, 4702
> Patience is a virtue.
> But if I wanted Patience,
> I would have become a Doctor.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20090309/a985fc1b/attachment.htm>
