[AG-TECH] Access Grid Audio Issue
Carnahan, Sean
scarnah at emory.edu
Fri Jan 23 11:24:29 CST 2009
Thanks for the quick responses! It appears to be both incoming and outgoing audio that is garbled. I am using Windows XP service pack 3 with an external usb sound device with echo cancellation for both sound input and output. I'm not sure exactly what the internal sound card is, however, I know its a standard on board for a Dell 755 system. But the internal sound card is not selected in AccessGrid and I haven't been able to find a way to configure an audio service to input audio from a usb microphone while also sending the output through the sound card (two different pieces of hardware). Also, I will have to check out the packet loss issue, I'm not sure how much I am getting right now. If anyone has any more suggestions I would love to hear them.
Thanks!
Sean
On 1/23/09 12:05 PM, "Todd Zimmerman" <todd.zimmerman at ubc.ca> wrote:
On Fri, 2009-01-23 at 10:40 -0500, Carnahan, Sean wrote:
> Hi Everyone,
> I am experiencing an audio issue with the Access Grid Setup I am
> working with right now. After about 20 minutes of use the audio
> becomes garbled and very distorted. If I close and reopen the venue
> client everything seems to work fine again. I am running on a unicast
> network and using a PC. Has anyone heard of this issue before and
> does anyone know of a possible fix?
Haven't heard of garbled audio on anything but a Mac. There was some
quality issues when choosing Also vs OSS drivers on Linux, but those I
believe are now resolved.
Is there packet loss associated with the garble? If not, can you select
a different audio device?
Is your outgoing garbled or just your incoming?? What OS / Sound Card
are you using?
Todd
This e-mail message (including any attachments) is for the sole use of
the intended recipient(s) and may contain confidential and privileged
information. If the reader of this message is not the intended
recipient, you are hereby notified that any dissemination, distribution
or copying of this message (including any attachments) is strictly
prohibited.
If you have received this message in error, please contact
the sender by reply e-mail message and destroy all copies of the
original message (including attachments).
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20090123/a0cbd39f/attachment.htm>
