[AG-TECH] Binding a bridge to a nic
Jon Johansson
jon.johansson at ualberta.ca
Fri Jun 27 12:09:55 CDT 2008
Hi Tom,
That works perfectly, thanks.
Jon.
~~ Jon I Johansson, Ph.D. * Tel.: (780) 492-9304 ~~
~~ jon.johansson at ualberta.ca * Fax.: (780) 492-1729 ~~
~~ * Office: G.S.B. 323C ~~
~~ Programmer/Analyst http://sciviz.aict.ualberta.ca ~~
~~ Research Computing Support ~~
~~ Room 352, General Services Building ~~
~~ Academic Information and Communication Technologies (AICT) ~~
~~ University of Alberta ~~
~~ Edmonton, Alberta, CANADA, T6G 2H1 ~~
! "This communication is intended for the use of the recipient to !
! which it is addressed, and may contain confidential, personal, !
! and/or privileged information. Please contact us immediately !
! if you are not the intended recipient of this communication. !
! If you are not the intended recipient of this communication, !
! do not copy, distribute, or take action on it. Any !
! communication received in error, or subsequent reply, should !
! be deleted or destroyed." !
-----Original Message-----
From: owner-ag-tech at mcs.anl.gov [mailto:owner-ag-tech at mcs.anl.gov] On Behalf
Of Thomas D. Uram
Sent: Thursday, June 26, 2008 5:26 PM
To: Jon Johansson
Cc: ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] Binding a bridge to a nic
Hi Jon:
Try setting the AG_HOSTNAME environment variable to the name/ip of the
NIC you want to use.
Tom
On 6/26/08 8:56 PM, Jon Johansson wrote:
> Hi,
> I'm moving my bridge to a new machine and I would like to bind
> the bridge process to a particular nic because the other one
> is going to be busy doing other stuff. I can't seem to make it
> work, though. I've used the 'listenPort' option to the Bridge3.py
> where
> IPADDRESS="129.128.125.61:23000"
> --listenPort=$IPADDRESS
> but listenPort is supposed to be an integer, only the port number.
> When I run the bridge without this, the ip address of the other
> nic appears in the bridge registry.
> Is there any way to force the bridge process to use a particular
> nic?
> Thanks,
> Jon.
