[AG-TECH] Binding a bridge to a nic
Thomas D. Uram
turam at mcs.anl.gov
Thu Jun 26 18:26:06 CDT 2008
Hi Jon:
Try setting the AG_HOSTNAME environment variable to the name/ip of the
NIC you want to use.
Tom
On 6/26/08 8:56 PM, Jon Johansson wrote:
> Hi,
> I'm moving my bridge to a new machine and I would like to bind
> the bridge process to a particular nic because the other one
> is going to be busy doing other stuff. I can't seem to make it
> work, though. I've used the 'listenPort' option to the Bridge3.py
> where
> IPADDRESS="129.128.125.61:23000"
> --listenPort=$IPADDRESS
> but listenPort is supposed to be an integer, only the port number.
> When I run the bridge without this, the ip address of the other
> nic appears in the bridge registry.
> Is there any way to force the bridge process to use a particular
> nic?
> Thanks,
> Jon.
> ~~ Jon I Johansson, Ph.D. * Tel.: (780) 492-9304 ~~
> ~~ jon.johansson at ualberta.ca * Fax.: (780) 492-1729 ~~
> ~~ * Office: G.S.B. 323C ~~
> ~~ Programmer/Analyst http://sciviz.aict.ualberta.ca ~~
> ~~ Research Computing Support ~~
> ~~ Room 352, General Services Building ~~
> ~~ Academic Information and Communication Technologies (AICT) ~~
> ~~ University of Alberta ~~
> ~~ Edmonton, Alberta, CANADA, T6G 2H1 ~~
> ! "This communication is intended for the use of the recipient to !
> ! which it is addressed, and may contain confidential, personal, !
> ! and/or privileged information. Please contact us immediately !
> ! if you are not the intended recipient of this communication. !
> ! If you are not the intended recipient of this communication, !
> ! do not copy, distribute, or take action on it. Any !
> ! communication received in error, or subsequent reply, should !
> ! be deleted or destroyed." !
