[AG-TECH] setting default codec for RAT under Linux (FC8) to other than L16-16K-Mono
Andrew Leahy
alfski at gmail.com
Thu Jun 12 20:21:41 CDT 2008
Thanks Doug, that appears to work fine.
Cheers, Andrew.
2008/6/13 Douglas Kosovic <douglask at itee.uq.edu.au>:
> Hi Andrew,
>> After changing the codec & transmission type in RAT how do I make it stick
>> after restarts of RAT?
>> OS: Linux Fedora Core 8, AG 3.1 (build 1)
>> RAT: rat-4.4.00-0.1.20071214svn.fc8
>> We've been experimenting with G726-40-16K-Mono (80kbps) vs the default
>> L16-16K-Mono (256kbps).
>> I can see where I could kludge something by replacing the string
>> "L16-16K-Mono" in
>> ~/.AccessGrid3/local_services/AudioService/AudioService.py
>> but simply replacing it with "G726-40-16K-Mono" doesn't work.
> You could try commenting out the options.append( "-f" ) and options.append(
> "L16-16K-Mono" ) lines in AudioService.py
> , so that RAT will then make the setting stick by storing it in
> ~/.RATdefaults.
> Doug
NewsFlash: Sydney Water discovers time travel...
"Make the most of the recent rain and install a rainwater tank."
(Waterwrap, Winter 2008)
