[AG-TECH] setting default codec for RAT under Linux (FC8) to other than L16-16K-Mono
Douglas Kosovic
douglask at itee.uq.edu.au
Thu Jun 12 20:06:01 CDT 2008
Hi Andrew,
> After changing the codec & transmission type in RAT how do I make it stick
> after restarts of RAT?
> OS: Linux Fedora Core 8, AG 3.1 (build 1)
> RAT: rat-4.4.00-0.1.20071214svn.fc8
> We've been experimenting with G726-40-16K-Mono (80kbps) vs the default
> L16-16K-Mono (256kbps).
> I can see where I could kludge something by replacing the string
> "L16-16K-Mono" in
> ~/.AccessGrid3/local_services/AudioService/AudioService.py
> but simply replacing it with "G726-40-16K-Mono" doesn't work.
You could try commenting out the options.append( "-f" ) and
options.append( "L16-16K-Mono" ) lines in AudioService.py
, so that RAT will then make the setting stick by storing it in
~/.RATdefaults.
Doug
